RCU Forums - View Single Post - Ram 750f ecu's?
Old 03-16-2004 | 10:41 AM
unknown
Default RE: Ram 750f ecu's?
Woketman you have some understanding about the engine and we never see eye to eye on some of these topic. I did all what i post to some of the RAM and Sophia turbines with no problem. I will post picture of the mod so you can understand what i'm talking about. The same pipe setup use to lube the bearing on RAM 750 f is the same on the autostart engines. The older engines may have two pipe line for top and bottom bearing but still works. or call the pro ( RTI)
