RE: Echo 8 Power Question?
It's a difficult task to get that Kit in the air from Hobby-lobby... Get yourself a Gyro to save some of the headaches!!!! Yes a four channel Radio will get it in the Air, you use a Y connector between the Throttle and Pitch slider
The Battery charger,,, Towers has a Triton charger that will charge all the batteries that you have or will get for $120... Radio shack or somewhere like that has the AC/DC converters which you plug into your wall outlet then plug your charger in to the converter.....
Hope this helps
