I had one of those before. And only god knows the trouble I had trying to get the CG balanced. The E-Starter is a nice looking plane but I'll never get another one. One main thing is you can't move the battery around without doing some cutting in the fuslage and using an extension for the battery wire. But if you want it to fly you must use all Micro Servos. Even for the Ailerons. It will still be tail heavy, but will fly. The only way to get the plane to balance perfectly is to put the battery behind the motor. But it's hard to get it to get it to stay.
Good Luck with that
