Real Flight or Aerofly Pro are both good choices, primarily because you can adjust wind speed and direction, as well as adjust things like the engines the plane uses.
FMS is free but will require that you buy a transmitter and an "interface" to connect it to your PC, and it doesn't give you the variables that the other two do.
Welcome to RCU, Good Luck, and most of all, have fun!
Dennis-
