RCU Forums - View Single Post - Sledge Wing Construction
Old 03-18-2004 | 09:43 AM
Wings-RCU's Avatar
Wings-RCU
Default RE: Sledge Wing Construction
I have found that the best and fastest way to build the sledge wing is to build it as a one piece wing. Simply replace the balsa sheeting and the leading edge with 48" balsa pieces. You avoid the big glue joint in the center of the wing making for a lighter stronger wing.
On my second sledge I also increased the rudder and elevator size slightly hoping to get similar rudder and elevator control authority as my OMP 540. Sure enough I ended up with the OMP rudder & elevator authority and of course the Sledge stability in all the 3D stuff. (I need all the help I can get).
ID:	112717   Click image for larger version
