RCU Forums - View Single Post - Avistar Balancing
Old 03-18-2004 | 12:32 PM
CrashBurn69
Default Avistar Balancing
Ok I am going to try and get my Avistar to balance because it is pretty nose heavy. I noticed it sets a little nose high on the table. Would I be better off adding larger main wheels to level it and for a little more weight behind the CG to get my balance closer. I am using an OS 46 AX on the nose. I have about a 35-40 degree down angle on the front. And if I add the self sticking lead weights do I just take some monokote and tack over it to cover it up? The inside compartment is so tight there is not a lot of room to move the battery and keep it secured, so I am hoping that the bigger wheels will do it, but its so close to the CG I dont know how much that will help.
