RCU Forums - View Single Post - GSP ARFs- Whose Responsible
Old 03-18-2004 | 01:59 PM
cstevec's Avatar
cstevec
Default RE: GSP ARFs- Whose Responsible
Not all that long ago we who fly RC planes spent months building from kits a plane that hopefully would be a good flyer when we were done. The kit contained a whole lot of wood (most of it useable) and a good (sometimes) set of blueprints and usually some wire to form the landing gear with. The instructions sucked, the cowls/wheel pants/control rods and more had to be built. The hobby was composed of a select group of dedicated people who had the patience for it. Nowadays, good kits are almost as complete as ARFs and it is possible to have a Carden Extra framed up and ready to cover in under a week if you are a competant builder.
ARFs have taken the real work out of building a plane but you still have to assemble the thing and install your own gear. There are 100's of threads here where modelers talk about chucking out all the hardware that came with the kits (ARFs) and replacing it with quality stuff. If they can tell that the hardware is no good why can't they remember to look at the wood they are screwing a part into and tell it's not strong enough to hold 88 oz. of torque supplied from a servo under deflection? A good modeler is going to look over the plane and re-enforce all the glue joints, make sure the firewall is secure/fuelproofed, iron down the loose covering and on and on and on. Sometimes even the best of us overlook something in our haste to get the latest hottie into the air. When I put together an ARF trainer for someone it usually takes about 8-10 hours depending on the kit. A aerobat like a 90-120 size Cap or Extra will take me 40-50 hours and if I am putting gas into a plane, it will take longer. I try to check everything and then I go over it all again.
ARFs aren't almost ready to fly, they are almost ready to assemble and most are starting to add the disclaimer that it is the modelers responsibility to look it over and reinforce/modify as required for our purposes. Those of us who don't feel the need to do that are usually the same ones who don't bother to pre-flight the planes before every flying session, skip the range checks at the beginning of the day and sometimes don't bother with between session maintenance/upkeep. Then too are the guys that just haven't learned yet, but they will.
Oh well, off my soap box now but I will leave you with one last thought for now. If you want a professional builder to assemble your .60 size ARF for you (and I will) it will cost you the price of the kit and all of the materials I have to provide or replace in the process. It will however be guranteed to fly,,,,,,,,,,once! I can't control how you fly, and I can't make you do the maintenance.
