RCU Forums - View Single Post - A 3D setup question
Old 06-01-2003 | 04:18 PM
FHHuber
Banned
Default A 3D setup question
Generally, I prefer to use exponential rather than dual rates. Having the center of the stick motion give relatively small movement of the control surface, makes it easy to fly smoothly, and then you still have full range at full stick. This also means you don't have to be messing with switches durring the flight. (and don't have to remember which switch is where to get the ailerons back to high rate...)
