RE: Concept 30 Opinions
515 's r your firend in the newbie stage plus they're lite 'r !!I still turn em "fast".Does your bird have the big r little blade grips.roughly 3mm or 4mm lead bolts should tell.I'm not sure but a sr tailboom maybe what you need.How tight are the linkages,do any of them easily comes off the balls.You can find cheap struts and drill them to size.And just looking at the shaft doesn't mean that it is straight.the picture will give others a view to become opioniated.I bought a junker from a hobby shop hung in there got it right now it's a nex deluxe with the right necessities 60 size landing gear presently!it needs a heading hold gyro I came under the cheap ole schoolr's and i kept getting mech gyro's , ole engines 36,32sx's,32f,28's.Factory repaired the big'r boy,salveged two for myself,sold 1,and got a carb off another etc.booms,blades,shafts you pretty much on your own.If you're gonna be around keep a few of these for yo self.
