Inverted Saito 100
I have mounted a Saito 100 after reviewing a few posts on the subject. I am having a little bit of an issue with it bogging down at low idle and then it quits.
Is this an issue of needing glow heat at low idle or is it more the low idle setting?
From what I had gathered from the other information that I had received, guys were running these inverted with out any issues at all and without any on board glow heat.
It is directly inverted as well, cylinder straight down, could that be a problem.
Thanks for any help.
