RCU Forums - View Single Post - Capiche 140 EX and IC version
Old 03-19-2004 | 04:21 AM
  #474
Sprink's Avatar
Sprink
Default RE: Capiche 140
ORIGINAL: Spaceclam
is this plane available yet? also, does it have any coupling in a knife edge, how much does it weigh, (without fuel) and will it snap out in any occasion that i could put it through with a ys 110 on 30%? is it an arf? how much does it cost and where can i get it? does it stall well, hover, parachute, etc. is there anything else i should know before i consider buying one?
Is it available - only to pre order customers (such as me ) Should be out properly soon though. Archie has the details
Coupling in KE - shouldn't do. If it does it will be tiny.
AUW should be about 9.5lb
You really need more than a 110, it is a 2metre job, for 140/160 engines.
Any plane will snap in certain conditions, C140 wont be different.
ARF - no this is a proper build it your self get your fingers dirty kit.
Very good for harriers parachutes etc. No need for flaperon mixing.
Only available from the UK at the moment.
