RCU Forums - View Single Post - Is this a big enough cooling hole?
Old 03-19-2004 | 09:02 AM
Luke 3D returns's Avatar
Luke 3D returns
Default RE: Is this a big enough cooling hole?
Youre forgetting something. Your large bus doesnt have a bloody great engine inside heating up all the air that goes through
When air is heated, it expands by a certain amount.
Lets say for example, all air flowing the cowl expands by 25% as a result of absorbing heat away from the engine.
So you effectively have 25% more air that should be coming out the back than the front.........
So unless your exit hole is 25% larger in area than your inlet hole, not all the hot air is going to escape.
follow?
