RCU Forums - View Single Post - Tunder Tiger .91 Four stroke mounting problem
Old 03-19-2004 | 02:37 PM
Sport_Pilot's Avatar
Sport_Pilot
Default RE: Tunder Tiger .91 Four stroke mounting problem
On many radial engine cowls it is possible to mount the engine up right, the motor mount holes to the firewall are often symetrical, just unscrew and flip over. The carb on the TT .91 and nearly all four strokes are mounted to be at the same position as a front rotery two stroke so it's not a problem with the engine. You should call World Models if you can't work it out.
