RE: Ace Extra 230 33% Fiberglass
I just finished building the balsa/ply/foam kit. I have a stock G-62 w/slimline muffler, 22/8 prop, 19 pounds dry, and it flys great. Plenty of power. I can climb out of hover. Lands nice and slow. The control throws are: Ailerons 1/2" up & down, Elevator 1" up & down, Rudder - as much as you can get. That's about right for low rate. Balance is 4 3/4" behind leading edge at the fuselage and it flys good at that setting. Two degrees right thrust. Thrust line, Wing and stab are set at 0 incedence.
Have fun!
