RCU Forums - View Single Post - C-130 updates
Old 03-20-2004 | 09:39 AM
  #324
jimcork1
Default wing panels
None of the wing panels are drilled for wiring. I used a 1/2 " aluminum tube heated carefully and burned a (straight) connecting hole through the entire wing. I used a 1/4" brass tubing heated slightly to make the channel for the wiring to the engines and flaps. I also used 1/2" paper tube to line the larger wing wire passage. vettdvr
