RE: wingspan and transferring tip cg to wing root question
You're over analizying the issue. Yeah in theory a wide fuselage with a highly tapered wing should take into account the small difference between the blanketed wing and the total wing. But in fact it's not an issue If it bothers you then use the true root and tip chords for your MAC calculation and reference the balance point to that.
