Clearcoat Reducing
I reduce my clear to a minimum of 150% and usually to 200 % I am also using only PPG 2021 or recently the PPG 2060 Flexed n Flat on my Phantom. It flows fantastic and will NOT orange peel or sag no matter how hard you try to make it do it. (With normal painting techniques.) The other added benefit is that you can get away without rubbing, sanding and buffing the clear if you want.
David Reid
