Switch Harness question?
I have a micro switch harness with no aux. charge jack. It just has two wires, a switch in the middle ( on the neg wire), with a male connector on one end and and a female connector on the other. The positive wire does not route through the swich, it simply goes from one connector to the other. My question is can I add a charge jack by simply splicing it into the wire on the battery side of the switch? If the switch is off, I can charge the battery without any current going to the reciver as that part of the circut would be open. Is this correct? I dont want to "jack up" my reciever. Thanks for any help.
Darren
