RE: Switch Harness question?
Darren:
If your planes last as long as mine you will eventually cut the plane open to change the battery pack. I have planes well over ten years old, the battery packs don't last that long. One, about 20 years old, is even on its third engine. Servos have all been replaced, even the original AM rx has been replaced with an FM unit. And others I have are on their second engines.
But if you are building this one without access, you really don't have any chioce. Either get a switch harness with a charging port, or add one to the switch harness you have.
Bill.
