RE: Inverted Saito 100
I'm also inverting a Saito 100, however, it's going in an EAA bipe. Per the instructions, Saito says to have the tank 4mm (talk about precision!) lower than the carb. Sounds like the problem could be solved by dropping the tank a bit. I've just run two tanks through mine and wow, this ain't no O.S. LA!
