Batterys Bookoo
The battery that is recommended by the kit manufacturer is usually OK for 5 - 7 minutes. A larger battery, more MaH, will give longer flight times but with a weight penalty. More MaH usually means larger cells and increased weight. A couple of ounces should not hurt. Several ounces will ground you. Try to find a local instructor and you can fly the Eindecker for while.
