RE: Multiplex Easy Star, construction, flight report
Thanks much. So the motor isn't noisy at all? Is most of the noise from electrics from the gearbox and props?
Can I use a different prop size, I'm assuming larger would be better to further reduce noise in addition to switching to the APC like you recommended. I saw a video or two of the Easy Star and it seemed quite buzzy. I'd need to reduce this quite a bit for myself to be able to fly it, especially hand launching brings it so close to the head. If it's not motor noise at least I won't have to worry about changing that out to an expensive unit, but if pusher props are inherently noiser than I may have to look into the Slow Stick some more, can that one be used direct drive? How noisy is it stock? The videos of it seem quieter, but with video, you never know how sensitve the mic is, if it's mixed differently, etc...
-any inisight to the different motor designs that I mentioned and there noise levels, it would help me understand alot more about what I need to look for.
thanks
Anthony
