RE: Kangaroo with a Prop,Need Help
I had a kangaroo with an OS 1.08 on it. Becareful not to ever-rotate or you will hit the prop, the airplane will b very light and the kangaroo hop is more prevalent then ever, and it DOES NOT fly the same as with a jet on it. It still flies well, but just not the same. I believe my thrust angle was level with the datum line, but I am not 100 percent sure.
Ted
