Throttle arm
Ran my engine for the first time yesterday, was very impressed, standard out the box tt.39 in the raptor 30 V2. only 1 problem though which I thought I should tell you all. The nut holding the trottle arm onto the carb is not tightened very well and at the end of the tank was loose the the servo was swinging it freely without effecting the carb at all because the nut had come loose. Checked all the other factory tightened nuts and they seemed fine. Something the check on the ARTF raptors.
