How to remove cylinder lining in OS ABC-engine?
I am trying to disassemble an old OS 25 marked 25F, I believe it is an FSR.
(the reason for the disassembly is to be able to clean out old rubber-like oil from the ball bearings.)
What is the trick neccesary to be able to remove the cylinder lining? I think it is an ABC-engine (Aluminium piston, Chromed Brass cylinder lining). I have tried to knock on it carefully with a (hammer + plastic pin) from the crankcase direction, but it refuses to "pop up".
It is necessary to heat up the whole engine block to a certain temperature?
Regards
Sverker
