RCU Forums - View Single Post - Incidence question?
Old 03-22-2004 | 07:02 AM
Kaos Rulz
Default RE: Incidence question?
I would first check for proper engine thrust line. If it's set up with a positive incidence, it will cause the plane to climb more as you increase the rpm's. If the engine incidence is OK, then go for the wing incidence.
