RCU Forums - View Single Post - New CA models Epsilon build (easy as pie)
Old 03-23-2004 | 06:56 AM
3dUkidding!
Default New CA models Epsilon build (easy as pie)
If weston start importing it'll be awsome for us brits as CA do do some amazing value models....if you work it out you can get a fantasy for between £400 to £500 pounds and that is alot of plane for you money
Sprink I can take picces of any part at you request as I wont have a chance to cover it for a while but as for room for a tank on CoG easy I rekon you could get a 20oz tank in!!
If you look at the side on pic you will see that the base of the cockpit is built up giving you tons of space
Luke funny you mention the ASP that is exactly what I have gone for....I do have an OS as back up though IF the asp turns out pants[:@]
But looking at it I rekon it'll be spot on ..... I think I'll bench run it in soon so I'll let you all know
