RE: nOOb help be, please be patient :)
I can;t really help you in this reguard but maybe i can point you in a better direction. Most of the people who hang out in these forums are fixed wing pilots, so to be honest you probably won;t have as much luck here as you would forums dedicated to rotary wing'ed pilots. With that said, i think Gisbert is mostly into helo's and used to run AFP (now he is using XTR) and he might be able to help or point you in the right direction anyway. I think you'll get more hits in a helocopter forum (like the one in RCU, or runryder.com) because you are asking how to setup the helocopter as opposed to i can;t get this thing to work. You might get a few hits here, but I am sure someone in a helo forum would be more apt to know. That is not to say there are not plenty of helo guys in this forum, but just a suggestion if people are not responding.
I am not a helo guy but most of the stuff worked for me just fine. Just make sure you don;t need to reverse some of the servo's . . . sure sounds like you have a servo moving the wrong direction there, but then again i don;t know anything about helo's other than I plant em quick whenever i fool around on any sim. Probably would help if you detailed exactly what your setup problems are.
