RCU Forums - View Single Post - Ram 500 starting problems
Old 06-19-2002 | 09:15 PM
rcpete347's Avatar
rcpete347
My Feedback: (251)
Default Ram 500
As I understand, on the C version the higher the number the less you are getting,fuel,gas.
Starting my Ram 500.
Actually my problem starts well the fuel ramping.
It ramps very fast and when it almost reaches idle spead it sputters, sputters and sometimes a blue flame is present. Most of the times it then quits.
The data terminal usually reads Run RPM Low.
When the engine does run the RPM readings are fine.
I would appreciate any help.
Thanks Rcpete
