Originally posted by rambat
Hello Pete; On the C02C version the only numbers that are reversed are the glow and the gas adjust parameters. On both of these parms the lower the number, the higher the plug voltage and the higher the gas flow.
I am a little confused here. My ECU is version B01L, and my understanding is that the lower the GAS parameter, the more gas you get. For example, a setting of 20 gives more gas than, say, a setting of 50. So this is the same as the C02C version you describe above.
I also understand that in cold weather, you need more gas than in hot weather, so you would DECREASE the numerical value of the GAS parameter to get more gas for the cold weather.
