RCU Forums - View Single Post - Ram 500 starting problems
Old 06-24-2002 | 10:01 PM
Brian B
Default Reverse Parameters
Originally posted by rambat
Brian; In the Bo1L version, the parameters are not reversed. A higher number increases the value and a lower number decreases it.
Well, this is interesting. The manual clearly states, on page 29, that a higher parameter gives LESS gas than a lower one. In fact it states that a parameter value of 0 will give maximum gas. In Tony's Tips, on the RAM web site, it also says that a higher parmeter value gives LESS gas. So why does my manual say this, and why does Tony say this if it is not true? No wonder I have so much trouble with my 500.
My manual is a year old, so I assume it reflects the ECUs that were provided with the engines at that time. It has just been a year since my second 500 was delivered, so I would naturally believe that the manual that came with it was correct. So, are you saying the manual is wrong?
