zero
Richard L, I'm glad to see and hear your zero is flying well. I have the green Zero and installed a 91 four stroke and still added 2.5 ounces more lead to that little shelf under the engine, my Question for you is where is the CG on you Zero ? mine seems to be tail heavy even though i balanced it buy the instruction manuel.This is the hardest to land plane I've ever landed, the elevator is so sensitive on my landings that I'm about to have a heart attack getting it to land smooth without bouncing and you know how easy it can be to stall a wing or elevator when you bounce on a landing. I've had so many near fatal landings i almost decided I'm just not capable of landing this plane with out causing some sort of damage somewhere, the only thing that has saved this plane is that its way overpowered with the .91 on it and i can go straight up if i need to get out of trouble. I'm beginning to think its still flying somewhat tail heavy. what do you think? CAN ANYONE EXPLAIN HOW TO POST PICTURES ON THE WEB PAGE, PICTURES THAT WHERE FIRST SCANNED FROM PRINTS?
