RCU Forums - View Single Post - ThunderTiger PRO .61 Overheating
Old 03-23-2004 | 10:17 PM
Texastbird's Avatar
Texastbird
Default RE: ThunderTiger PRO .61 Overheating
Hi,
I would look for bubbles in the fuel line when the plane is in the air. It can seem rich but still be going lean when this happens. A defective or unbalanced prop can cause this (and the vibration). Be sure your fuel has enough oil. A little castor might help. Otherwise there might be something wrong with the engine. A peeling cylinder liner is the first thing that comes to mind. Good luck.
