RE: thunder tiger pro .61 help?!?
Fox plugs are OK, but not the idle bar plug. Fox Gold Post should work fine. But since Tower doesn't carry them not many shops do. I like the Enya #3 when having problems. You need a hotter plug when using 5% nitro, which an Enya #3 is. The OS #8 is fine if using 10% or 15% nitro. I think the combination of low nitro and a fairly cold plug is your problem.
