I received the following reply from the FCC:
-----Original Message-----
[email protected]]
Sent: Wednesday, March 24, 2004 7:02 AM
To: JR
Subject: FCC Consumer Center response from representative TSR41
You are receiving this email in response to your inquiry to the FCC on 3/24/2004 9:57:43 AM.
The end user is not to change out crystals or make modification to R/C equipment. The end user may switch out certificated modules.
If you need further clarification, an official interpretation from the Commission requires the filing of a petition for declaratory ruling pursuant to Section 1.2 of Title 47 of the Code of Federal Regulations, which states:
s 1.2 Declaratory rulings.
The Commission may, in accordance with section 5(d) of the Administrative Procedure Act, on motion or on its own motion issue a declaratory ruling terminating a controversy or removing uncertainty.
Petitions are filed with the Secretary of the FCC. Information is available at:
http://www.fcc.gov/osec/
See: "Guidelines for Filing Paper Documents"
The address for filing petitions for declaratory ruling is:
The Secretary
Federal Communications Commission
Counter TWA 325
445 12th St., N.W.
Washington, DC 20554
Representative Number : TSR41
