RCU Forums - View Single Post - Just got AFP and need some help!
Old 03-25-2004 | 09:18 AM
rajul's Avatar
rajul
Moderator
My Feedback: (58)
Default RE: Just got AFP and need some help!
Set your dual rates on your radio. Then calibrate in AFP with your radio set on high rate.
This is Maarten's setup for the Extra in the video :
Throws: all 60° except rudder= 50°
CG: +3.0 cm
eng: 12 kw, torque: 40%
prop: 31x10.6 max rpm= 8200
gross weight= 15900g
Change the 7.0 in the first column to 3.0 for the cg
As for the weight, just reduce the fuse weight by 1 kg.
Enjoy !
