RCU Forums - View Single Post - Help with LT-40 Tail wheel linkage
Old 03-25-2004 | 01:49 PM
JimTrainor
Default RE: Help with LT-40 Tail wheel linkage
I used this tail gear:
http://www.greathobbies.com/scart/pr...Number=CBA5516
... except I put a small bend in the leaf springs.
It sticks out about an inch behind the rear of the fuse, just under the elevator.
It is (will be) driven using a second push rod from the rudder servo. No direct link to the
rudder. Pull-pull cables to the servo would work well also.
