RCU Forums - View Single Post - Help with LT-40 Tail wheel linkage
Old 03-25-2004 | 11:42 PM
SooprDink
Default RE: Help with LT-40 Tail wheel linkage
benngrp,
You just stated what I was thinking about all day after my initial post. I had new mains made up and they will be mounted at the leading edge of the wing. I will have a second control rod that comes off the rudder servo and it will exit the opposite side of the rudder and on the bottom. My tail wheel assembly uses a 3\32" rod that I can bend to a 90. Now how do I connect the tail wheel control rod to the 90 that I just bent in the tail wheel rod? Another idea i had was to not bend a 90 but put on a bell crank type of arm on the top of the tail wheel rod. Do they make something like that for 3\32 inch rod? Something like a wheel collar but with a plastic arm that has holes in it like a servo arm. This is my last hurdle... to find out how to connect the control rod from the servo to the 3\32 rod of the tail wheel. Thanks all
Shaun
