Gunny
I ordered the airfilter. If it shows up before the weekend, I will run it again and do some adjustment so the will run fine with the filter. I also will have to test again my kill switch. I use the RC100 from RCATSYSTEMS (
http://rcatsystems.com/electronics.php) and I don't know if the vibration could have caused the problems. Once I confirmed that the setup will work I will put the motor back into the Giles and ---- hope I don't have a dead stick / need 200+ flips to start the engine. I will let you know. Question: Do you have any experience with the RC100?
Regards
Rainer
