"My tail wheel assembly uses a 3\32" rod that I can bend to a 90. Now how do I connect the tail wheel control rod to the 90 that I just bent in the tail wheel rod? "
To connect a wire to a wire.
http://www2.towerhobbies.com/cgi-bin...?&I=LXD919&P=0 Use a strip aileron horn on the 90 degree arm that was bent at the tail wheel. Then use a solder on clevis on the pushrod wire from the servo to connect the two.
John
