RCU Forums - View Single Post - www.Learning 3D step by step
Old 03-26-2004 | 11:39 AM
  #439
Ian.W's Avatar
Ian.W
Default RE: WWW. LEARNING 3D-STEP BY STEP
ORIGINAL: Italian-flyer
[8D]Hi people
[color=red]Dear "ifixairplanes"
If you want to learn hovering, use low rate. Be gentle with elevator, rudder, ailerons and trottle. It's very difficult to hover because you must get the balance of 4 inputs. Use trottle up and down gently and continuously. Use the others in the same way. Give a wild inputs to the rudder for big corrections.
[&:]As it's very difficult, you can't expect to learn in a little time. I too can't hover. But I'll learn.
[color=green]Vittorio from Italy[sm=sunsmiley.gif]a beautiful country.
No no no no no! use as much rate as possible, just be gental. yuse expo to calm it down around the center so small sick movmets are small but if you muck up you shove in big stick movements which will make huge surface deflections to get yourself out of a pickle.
