RE: Help with LT-40 Tail wheel linkage
Or do like the LT25, and use pull-pull from a tiller in the fuse connected to the rudder servo. I used that set up, but didn't use the kit supplied steel cable as I ran my antenna down the inside of the fuse. I used nylon no-streach fishing leader. So far after a year of a lot of use, there is no slop. Works GREAT and is very easy to do.
