i run 5k up fron, 7k in the middle, and 1k in the rear. It is on rails down the straights...... and i can slide the rear end out if i want to around the tighter corners. it really grips.... and transfers the engines full potential to the ground. I was amazed at the difference between the stock grease, and the ofna diff fluids.
