RCU Forums - View Single Post - somethin extra question?
Old 03-27-2004 | 12:35 PM
tonystro
Default RE: somethin extra question?
We have had six SEs flying in our club during the past year, two of them mine. The wing holding methods were equally split between plastic zip ties and #64 rubber bands triple looped. One of my planes uses rubber bands, the other is zip tied. I have not noticed a problem with either method. I have heard that a flyer in another local club had his wings come apart while doing multiple snap rolls, but haven't had the opportunity to speak to him about it.
I do recommend that you double-, then triple-check that the 'J' bolts are securely mounted into the root rib. One of our flyers chose to drill the holes "slightly larger" (because he was having trouble threading the J bolts in), and also forgot to epoxy the bolts in. [X(] Fortunately a bolt pulled out when he assembled the plane at the field.....rather than during a flight. He now has dozens of flights on his SE without a problem.
I think you will enjoy your SE. It's not fast, but it is smooth with no bad habits!
