RE: Help...I am a little slow
Hello Help I don't have any experience with this plane and I know that I am not an expert on electronics not even at the least. But I ill try to extend what I know to you. As for connecting the battery to the receiver since this is an electric plane then it probably has a speed controller so what you do is connect the battery to the speed controller and the speed controller to the receiver on the speed servo connection. As for taking the battery out of your plane its nice not to have to haul your plane out to the car when you want to charge it. Normally you just charge the battery until it get a little warm because that means that the battery cannot hold any more charge so it is converting the power to heat. hope any of this info helps you.
