RCU Forums - View Single Post - rascal 110-g26
Old 03-27-2004 | 09:15 PM
GearDown52
Default RE: rascal 110-g26
I am sorry that know one has replied to your post, so here goes. I have one with a g-26 swinging a 17-8 apc. I put the rudder servo in the tail. The starting balance is 4.5 inches back from the leading edge and with this set up, the plane balances perfect. No added weight. Sig provides the sevo cut out for the rudder already. Just cut out the covering and make a pushrod. I really love mine. A friend in the club has one wiyh the same set up as mine. It will torque foll, knife edge at a quarter throttle and flys inverted really good. I fly mine with hi- tech 605's in the tail and standerds in the wing on a 6 volt battery. I hope this helps you. Good luck.
