RE: Sheilded cable
HI Dirtybird, do you know a better way, I personally do not like having connections, so I usually cut the lead off the servo and run a new cable the exact lenght back to the receiver.I have a spool of 2 wire shielded cable,it has the ground between the shield and the outer covering, maybe I should get some 3 wire and join the black and ground at the receiver like I"ve read on other posts. Can some of you electrial experts chime in on this post.
Rcpete
