Sizing different props for the same engines
Hobbsy,
Actually I should have stated that this would be true usually at low power settings, often at high power settings it would not be true. But a dive at idle would indeed cause the prop to turn the engine instead of the other way around. Even if the idle is 1 RPM over that on the ground then the prop is driving the engine and efficiency is negative.
