hello
when i decided to buy the se, i was concerned about the way the wings are attached.
while building it, i decided to put two small screws to hold the wings.
i used the same bolts sig uses for the engine mount.
drilled the wing and added a nut for it.
on the inside i glued a washer to keep the bolt from braking the balsa fuse..
when i get to the field i screw the bolts, put a rubber band and turn the hooks so they cannot get out.
never had any problem. flying her for more than a year and a half [8D]
only truble was finding a screwdriver... found a small one and cut it so it would fit...
