RCU Forums - View Single Post - Using acetone for dope thinner???
Old 03-28-2004 | 06:09 PM
LouW's Avatar
LouW
Default RE: Using acetone for dope thinner???
By far the best way is to use the thinner made for the particular dope. There are many formulations of lacquer thinner some of which work quite well, and some that don't. The only way to tell is to try it and see. Dope thinner is quite cheap and should be available at the same place dope is sold. Unless you just want to be an experimental chemist, it doesn't make much sense to use anything else.
